1994 Subaru Impreza Missfiring new engine
ALL1971
  • 1994 SUBARU IMPREZA
Engine Performance problem
1994 Subaru Impreza 4 cyl Four Wheel Drive Manual
hi hope someone can help I have just had an engine rebuild with v9 crank and maul pistons and rods. Put engine back in car this week and it seems to have a missfire on cylinder 3, I have replaced coil pack and injector and still the same im stuck now please help
Thursday, June 26th, 2008 AT 8:54 AM
KHLOW2008
  • 41,814 POSTS
Hi all1971,
Check the compression, is it equal or almost equal with the rest?
If the valve lifters are hydraulic, you need to release the pressure to allow the valves to sit fully with enough clearance.
Check the valve clearances if non hydraulic lifters.
Check for vacumn leakage on manifold for No 3 cylinder.
Sunday, June 29th, 2008 AT 3:03 AM
