1993 Subaru Impreza Intermitent starting problem.
210,000 MILES • 4 CYL • 2WD • MANUAL
FREECLIMBINGMONKEY
I have taken the car to a couple of mechanics, the computer has no errors logged, it always atarts fine when at the mechanics. At home it won't do hot starts. If you turn it off then try to turn it on again, it turns over but won't start. Mechanis said it might be the fuel pump, but that seems to be fine. The enging light comes on some times, but won't register on the computer. Is painful. Great car otherwise. Had any problems like this? any suggestions?
Thanks.
Jun 16, 2010 at 3:03 PM
  • 75,988 POSTS
Hard starts could be caused by a lost of residual fuel pressure that can be caused by a leaking injectors and fuel pressure regulator
Jun 16, 2010 at 11:09 PM
