1988 Subaru GL Engine will not idle when air temperture is
238,205 MILES • 4 CYL • FWD • MANUAL
2SLOW
As spring comes and the air tempertures rise my Gl Wagon runs better. It was 95 degrees air temperture today, it ran perfect. It past the smog test todaywith great marks. The test read that it idles at 698 rpms that is great. This condition leaves every spring and comes back in the fall. Would a disgnositic engine test show the part that has failed? I checked the vacuum lines they all looked and felt very good. I would appreciate you help as this is my work car.
Apr 20, 2009 at 4:57 PM
KHLOW2008
  • 41,812 POSTS
Hi 2slow,
Thank you for the donation.
What is the problem that you are facing? Engine stalling due to poor idling or idling speed too high?
Putting the vehicle on a diagnostic would allow you to check each component and verify if they are working within specs. It might or moight not tell you if anything is wrong of the item concerned is not controlled by the ECU.
Apr 21, 2009 at 4:29 AM
