1986 Subaru GL oil presure
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
BOBSEEMAN
My 1986 subaru gl the oil pressure starts out at 45+
psi but once the engine gets warm it drops to almost
0. do the oil pumps go bad on these or may be cam or main bearings?
thanks bob
Mar 27, 2010 at 1:20 PM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch.If abnormal could mean oil pump and/or engine bearing.
Mar 27, 2010 at 6:34 PM
