1986 Subaru GL New engine, old car
1986 SUBARU GL
201,000 MILES • 4 CYL • 4WD • MANUAL
CRAZYBRIT318
I've had this subaru for many months and have enjoyed every aspect of it but one. The 1.8 L horizontally opposed four cylinder engine only puts out 85 horses. thats rated. Just yesterday, a friend offeresd me a 305 V8 out of a chevy nova he has for only $50. I of course jumped on the offer knowing it runs and has a four barrel carb that i can take too. The only problem is, i don't know how, or if i'll be able to fit this under my hood and make it work for me. My intent is to make it a summer project. Any help would be appreciated.
Alastair
Feb 6, 2009 at 5:24 AM
ZACKMAN
  • 4,202 POSTS
Well... Where there is a will, there is a way. But word of caution. The project that you are trying to accomplish is not an easy task. This is not a simple engine swap, say a 350 motor from a 79 Chevy 1/2 ton truck to an 82 Camaro.
In your case, the 350 will fit, barely. You may have to cut an opening in the firewall to make room for the transmission bellhousing. Speaking on transmission, well.. we'll get to that in a minute. Let's finish talking about the motor. You will need to custom fit the subframe to accept the larger motor, obviously. You need to weld brackets for the engine mounts on the subframe. You may have to either raise the hood or cut a hole on the roof. The air cleaner and intake manifold of the 350 will not clear the hood when it is closed. You will also need to get a much larger radiator to compensate the heat the 350 will be generating. That puny stock radiator is not going to cut it.
Now, the transmission. Your Subie transmission will not bolt onto the 350. Even if it could, you'll twist that transmission within minutes from all the torque. So you will need to find either a Turbo 350 or 400, may be a T700 with an overdrive. That transmission is about 18" longer and maybe 6 if not 9" wider that that of the Subie. You may need to cut the floor just a bit to fit. Remember, you already have to cut the firewall for the motor. From the transmission, obviously you'll need a drive shaft. The Subie shaft will be too small and the car came with CV axle. You will need a shortened Chevy drive shaft and mated to a shortened Chevy rear end.
Front axles that came with the Subie will have to be taken out. There is no place to mount the CV shafts into your new transmission. You will also need a solid front end, probably off a Chevy car of the similar year (will have to be shortened, of course). Let's talk the front suspension and steering. You have rack and pinion steering system. Your steering column is attached to the r&p. Your "new" transmission will be in the way of the current rack and pinion steering, I am not even sure as to where to put your steering system.
Then you have to figure out how to attach your steering column (that was on the r&p) on the steering system that you will have to adapt (I don't where that will come from)
I assume that this will be a daily driver, so you will need this vehicle to pass state inspection. So, you will need a running dashboard- speedometer, and all sort. Your engine wiring will have to be adapted to a Chevy end clips. You may call Painless Wiring (that is what they do). They may custom make you one with a Chevy plugs on one end, but a Subaru plugs on the other.
That is all for now, something for you to think about. Personally, I have done engine swap (Nissan 1.6L to 2.0L, Honda 1.5L SOHC to 1.8L DOHC, GM 3.1L to 3.8L Supercharged, and helped a little Dodge 2.5L to 3.5L), but I have never done a Franken-swap. Those swaps were not easy, and consumes a lot of money and time.
Good luck.....
Feb 6, 2009 at 10:21 AM
ZACKMAN
  • 4,202 POSTS
[quote:8aa9e34786]
thank you very much. i had suspicions that it would be something ridiculous, but my auto knowledge is neophite at best. this vehicle is the first car i've bought on my own and i want to keep it even if it means the work will take it off the road for lengthy periods of time. i'll probably end up buying a simple driver for the summer while i work. so if i may, do you have any idea what the estimated cost might be assuming the parts i buy aren't all brand new and the labor is free?[/quote:8aa9e34786]
This is just the basic and the least expensive I know. These are wrecking yard prices.
Transmission 125
Engine mounts 100
Front and rear ends 250
Drive line 50
Steering (pump, gear box, column, linkage, etc..) 300
Brake system 300
Wiring (new) 200 - 500 (estimate) call Painless Wiring for actual price.
Feb 8, 2009 at 2:48 PM
