1985 Subaru GL
MRSPOT
Transmission problem
1985 Subaru GL 4 cyl Four Wheel Drive Automatic
blew differential seal replaced it and filter.jacked up frount end up so i could get under it.now no leaks but wont move in eany gear .wondering if fluid came out of torqconverter.if so is there a easy way to replace fluid
Sep 2, 2009 at 3:24 PM
  • 31,937 POSTS
Hi there,
The torque converter and transmission oil is the same, if the trans oil is correct the torque converter is full, make sure that it is selection gears at the transmission.
mark (mhpautos)
Sep 2, 2009 at 3:33 PM
