2004 Subaru Forester High pitch noice from car
E BIXLER
Noises problem
2004 Subaru Forester All Wheel Drive Automatic
What is causing a high pitched noise coming from the car-front of the car; when both on and turned off?
Feb 3, 2009 at 9:38 AM
  • 110,248 POSTS
You hear the noise when the engine is off and the car is stopped? Can you tell what area it is coming from? If front, could it be the radiator bleeding off pressure?
Feb 25, 2009 at 5:25 AM
JANQE
My high pitch hum seems to be coming from the rear. Starts at around 40 mph after driving a couple of blocks and gets louder the faster I go. Does seem to come and go on the freeway but definitely comes back when I take my foot off the accelerator and coast. No sound while I'm stopped. Turning doesn't seem to affect it either.
Mar 29, 2010 at 9:53 AM
  • 110,248 POSTS
Chances are there is a problem with a bearing in the differential. Have you checked for any excessive in and out play in the rear tires? Any play where the driveshaft attached to the differential?
Mar 29, 2010 at 4:30 PM
