2004 Subaru Forester Engine Air Filter
72,000 MILES • 4 CYL • AWD • MANUAL
WSBM94
I have a 2004 Subaru Forester (non-turbocharged), and recently attempted to change the engine air filter. There is a bolt that secures the housing to the car, and the usual clips. I can remove the bolt and the clips, but the housing is positioned so it is slightly under the body, toward the cabin. I cannot lift it out to adequately access the entire filter to remove it. Additionally, it seems the hose should be removed as well, but there isn't a clamp on it.
I've replaced air filter's before on at least 3 other types of cars I've had, but this one is positioned to make it as hard as possible. What's the trick for this model and year?
Dec 13, 2008 at 3:31 AM
  • 110,251 POSTS
If it is positioned under the body, you will most likely need to remove the entire air filter box to access it.
Feb 25, 2009 at 5:47 AM
