2004 Subaru Forester Antifreeze overflows, gurgles, then eq
DFUTEY1
Engine Cooling problem
2004 Subaru Forester 4 cyl All Wheel Drive 75000 miles
This issues started last week. I noticed anitfreeze odor and spill on the garage floor after driving. Reservoir tank was completely filled, no a/f in the upper hose to the radiator. After the car sat for a couple minutes, I heard gurgling and the a/f drained from the overflow and I could feel a/f in the hose.
I took it to my trusted mechanic and we thought stuck thermostat. It was replaced along with a/f. A week latter same thing happen, overflowed, reservoir tank completely full (and bubbling from heat), no a/f in the upper hose, sits then equilizes. This happened twice in one day and I noticed that it seemed to occured if the car did not have a chance to cool a little, so it occured after continous dirving/mulitple short stops.
Thermostat seems working probably as the temp guage goes up then settles back, running mostly where it always does/did.
Suggestions appreciated.
Mar 14, 2008 at 12:39 AM
PUMAMEOW
I am experiencing the same problem - were you able to fix your problem and if yes, how was it fixed, any info would be GREATLY appreciated
Nov 1, 2008 at 1:16 PM
