Suspension problem
2003 Subaru Forester All Wheel Drive Manual 2.5X miles
Hi, I've made an attempt at replacing the front coil over strut suspension on my Subaru Forester 2003 2.5 X and run into trouble. When I removed the strut, the wheel assemble (rotor and brake caliper) flopped outboard onto my lap. Subsequently the wheels drive shaft cv joint, came away from the races within the six sided housing at the engine. I unclipped the boot slipped it back and two of the three bearing rings fell out, along with a lot of grease. Can this bearing set up be rebuilt? Or does it mean it's shot if the bearings come away from their posts? What should I do?
Jul 15, 2008 at 6:08 PM
