2002 Subaru Forester Fog Light
2002 SUBARU FORESTER
260,000 MILES • 4 CYL • AWD • MANUAL
XIANGSUOLIU
It seems the foglight itself does not have problem, but the light is not on when I press the fog light button. I guess that the problem might be in the circuit, but am not sure how to check.
Can you give me some suggestion?
Thanks.
Lew
Sep 29, 2010 at 11:18 PM
MIKE H R
  • 3,094 POSTS
Check number 6 fuse {fog light} If fuse is all right then check to see if you are getting power to the lights. If not then the problem would be with the fog light relay. There are two fuse boxes. One under the hood on the drivers side and the one on the drivers side under the dash
Oct 7, 2010 at 2:46 AM
