2002 Subaru Forester engine oil leak into spark plug hole
120,000 MILES • 4 CYL • 4WD • AUTOMATIC
CMPCHANG
engine oil leak into spark plug hole. And some oil leak in the PVC valve area. Need to add some oil after drive ~2000 mile. What is the root cause? thanks,
Ray
Oct 30, 2009 at 4:51 AM
CRZYDRVR
  • 432 POSTS
The most likley problem is the valve cover o-ring grommets. Very unlikley that the head has a crack in it.
Dec 8, 2009 at 3:40 PM
