2002 Subaru Forester
210,000 MILES • 4 CYL • AWD • MANUAL
TRACKER18_06
Recently I have had a problem with the factory installed radio in my 2002 Subaru Forrester. When driving the radio becomes "locked" - I can't adjust the volume, change the station or turn it off. Further, the radio continues to play even when I turn off the ignition and remove the key. This does not happen every time I drive the car, only about half the time. Is this some type of short?
Sep 30, 2009 at 12:57 AM
CRZYDRVR
  • 432 POSTS
Probably just a bad unit. If it were a short you most likely have more things going on than just that.
Oct 4, 2009 at 7:33 PM
