2001 Subaru Forester Gasoline in crankcase oil
2001 SUBARU FORESTER
MRED52
Engine Performance problem
2001 Subaru Forester 4 cyl All Wheel Drive Automatic 152k miles
Where are the probable ways gasoline can into the crank case oil. I just had some problems with the timing and they said they drained out 6 QTS of oil . They said it was passing thru the rings , and i can not belive that. The car has been running good and there is no exaust smoke. THANK YOU , ED
Mar 24, 2008 at 11:07 AM
BMRFIXIT
  • 19,053 POSTS
leaking injector will cause that but you will get a misfire code
or hard start
Mar 24, 2008 at 1:29 PM
