timing belt was broken when tension assembly holder bolt loosened and sheared off.
It appears that the spacer washer between the timing belt tensioner and cover assembly was left out when timing belt was changed. Could this have caused the bolt to loosen?
Nov 19, 2009 at 10:08 AM
