2000 Subaru Forester timing belt failure
2000 SUBARU FORESTER
180,000 MILES • 4 CYL • AWD • MANUAL
REBOB15
timing belt was broken when tension assembly holder bolt loosened and sheared off.
It appears that the spacer washer between the timing belt tensioner and cover assembly was left out when timing belt was changed. Could this have caused the bolt to loosen?
Nov 19, 2009 at 6:08 PM
CRZYDRVR
  • 432 POSTS
It sure could cause premature failure if it has altered the alignment of the belt.
Dec 7, 2009 at 9:54 PM
