1999 Subaru Forester Binding noise
1999SUBIE
Drive Train Axles Bearings problem
1999 Subaru Forester 4 cyl All Wheel Drive Automatic
I have a 1999 Forester and just recently it started making a binding/grinding noise when you turn the weel all the way to the right or left and drive real slow. You'll only hear it if you're taking a slow sharp turn or driving in a circle. What is the cause and solution for this issue?
Otherwise car drives fine.
Mar 7, 2010 at 12:31 AM
CRZYDRVR
  • 432 POSTS
It sounds to me that the issue may be on or both of the c.v axles. Check for torn boots. Its the first sign.
Mar 16, 2010 at 1:21 AM
