1999 Subaru Forester
125,000 MILES • 4 CYL • AWD • AUTOMATIC
MOOREMD1
At low gears, the car shifts smoothly. As I move up to higher speeds, it seems to pause and swim for a bit before catching, and then accelerates rapidly. mechanic is speaking about solenoids, codes, etc, wihich is gibberish to me. Any insight to what the problem could be? other than this, car runs very well.
Thanks
Feb 10, 2009 at 2:11 AM
  • 110,251 POSTS
Hi:
The shift solenoids are in the trans (valve body) and the computer tells the trans when to shift through them. Yes this could cause a shift problem. As far as the codes, when a problem occurrs, if it last long enough, the computer will recorde it and save the information in the form of a trouble code. If there is a problem with a shift solenoid, the computer may have saved the info. If the mechanic scans the computer, it may provide a code that will identify the problem and where it is coming from.
Keep in mind, mechanics will usually charge you to scan the computer. However, many nationally recognized parts stores will do it for free.
Feb 25, 2009 at 5:23 AM
