1998 Subaru Forester slight miss
17,000 MILES • 4 CYL • AWD • MANUAL
DECKER109
This was all done by a mechanic. Had a code to replace cats,did that. Was told I needed a tune up,did that,New plugs,wires fuel filter air filter.Still my engine was missing.We have now replaced the mass air sensor.I am getting no code and I still have a slight miss.Why?
Jul 4, 2010 at 5:34 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jul 4, 2010 at 8:50 AM
