1998 Subaru Forester Rattling noise
131,500 MILES • 4 CYL • AWD • AUTOMATIC
USAF GUY
I'm hearing a low rattling/knocking sound from my 98 Subaru Forester's engine. It doesn't sound like a rod bearing failure--at least not like rod bearings I've heard before (not a consistently loud knock...)
It's loud in the morning when cold, settles down a bit when it warms up, but never really goes away at idle--sounds almost like dieseling from a few feet away, but the knock/rattle is audible up close.
When driving at 2K plus RPM flat and level road, no noise, but when accelerating/decelerating/climbing hills the rattle becomes more pronounced--from the driver's seat it almost sounds like a loose heat shield.
No loss of performance yet, just the noise.
Anyone out there who might have a lead on this?
Dec 17, 2009 at 4:23 AM
  • 110,246 POSTS
Chances are one of the catylatic converters has come loose inside. Tale a rubber mallot and tap on the converter to see if that is the sound. Also, there are a lot of heat shields under the car so check them too.
Let me know what you find, and thanks for using 2carpros.com.
Dec 17, 2009 at 7:32 AM
