1998 Subaru Forester not starting
BANKLIN
  • 1998 SUBARU FORESTER
Engine Mechanical problem
1998 Subaru Forester 4 cyl Four Wheel Drive Automatic
my subaru turbo had a problem a few months ago when I pulled into the drive it cut out and would not start again so I towed to a friend of mine and on route I turned it over and it started and again last week it done it but wont start at all now there is fuel and spark help
Thursday, January 7th, 2010 AT 3:51 PM
LIONHEARTKNIGHT
  • 8 POSTS
Make a detailed check of the sensors, Timing Belt Sensor, Crank Position Sensor, and Throttle Position Sensor. If there is spark and there's fuel in the line, check if the Injectors are working.
Thursday, September 16th, 2010 AT 8:36 PM
