1998 Subaru Forester brakes
80,000 MILES • 4 CYL • 4WD • AUTOMATIC
ARTAZZ
Peddle is low when applied. Goes below the gas peddle.
16K no brake job (new rotors&pads)
I hear this is some dwhat normal on Subaru!!!!
Thanks
Feb 23, 2008 at 10:25 AM
BLACKOP555
  • 10,386 POSTS
Have you just noticed this problem? has it always been low or recently did this happen?
Feb 23, 2008 at 1:29 PM
ARTAZZ
Sorry I can't answer the question as I just purchased
the car. I have been in a few outbacks and the peddle seem low in them. Also I see that statement
listed a lot on the net. The previous owner did have a brake job about 16K ago ( by a professional )
I have only driven it 3 or 400 miles.
Thnaks for your quick reply!
Feb 24, 2008 at 12:40 PM
BLACKOP555
  • 10,386 POSTS
does it stop just fine when the brakes are applied?
Feb 24, 2008 at 2:02 PM
ARTAZZ
blackopp555
Yes it stops fine. The Problem!! If I attempt an emergency stop and just miss the brake by a small
amount I could press the gas peddle to at least
1/2 throttle. Not to good.
ThanksTazz
Feb 25, 2008 at 12:12 PM
BLACKOP555
  • 10,386 POSTS
take a pedal off of another vehicle and put it on, i belive it is the style of the brake that is doing that since it stops fine, you could take it off and bend it up a bit, it will require a bit of mod's on your half.
Ive had 3 early modle fords with the same problem, i took the pedal off MIG welded a little bracket on it so it would hold the pedal out further when the brakes were applied
Feb 25, 2008 at 1:59 PM
