2003 Subaru Baja whining noise
80,000 MILES • 4 CYL • AWD • MANUAL
MSIBERT851
My Subaru start at about 25 miles per hr a whining noise that accerlates as the speed increases---it is still there if the car is taken out of gear and then goes down in pitch as the car slows down
Jan 17, 2010 at 5:12 AM
LAUKWVU
[quote:a8e67a17de="msibert851"]Noises problem
2003 Subaru Baja 4 cyl All Wheel Drive Manual 80,000 miles
My Subaru start at about 25 miles per hr a whining noise that accerlates as the speed increases---it is still there if the car is taken out of gear and then goes down in pitch as the car slows down[/quote:a8e67a17de]
I have a the exact prob going on with mine(manual trans) after noise finally settled in all the time its been about 3K miles and same noise nothing broken yet. i would like an anwer also
Jan 18, 2010 at 3:36 PM
MSIBERT851
mechinic thinks it could be in the differential and could be barring noise---we changed the fluid and hope for the best---mechanic says go ahead and drive--itf it gets worse i will know because of the vibration and louder noise
Jan 19, 2010 at 7:13 AM
LAUKWVU
[quote:39745431c5="msibert851"]mechinic thinks it could be in the differential and could be barring noise---we changed the fluid and hope for the best---mechanic says go ahead and drive--itf it gets worse i will know because of the vibration and louder noise[/quote:39745431c5]
can you message me back if that fixed the problem? thanks a lot
Jan 22, 2010 at 7:16 AM
LAUKWVU
[quote:5fb461a0d0="msibert851"]mechinic thinks it could be in the differential and could be barring noise---we changed the fluid and hope for the best---mechanic says go ahead and drive--itf it gets worse i will know because of the vibration and louder noise[/quote:5fb461a0d0]
Did that work for your subaru, my baja still making that whinning noise from 25mph on, still nothing broken, gas mileage stays the same, no overheating. about to get my front diff fluid changed. Let me know if it fixed your problem thanks
Mar 27, 2010 at 1:36 AM
