2003 Subaru Baja timing belt + water pump replacement
F250PHIL
Engine Mechanical problem
2003 Subaru Baja 4 cyl All Wheel Drive Automatic
I was quoted a price of 460.00$ parts and labor from a subaru dealer for repl. timing belt+water pump. Does this figure seem correct? I purchaced a kit which contains belt, w.pump, 2 idler pulleys, 2 drive pulleys, tensioner, cam seals, thermostat + gaskets for 260.00$ The price i was given must be for the belt + water pump only, if my math is correct.[img:f5d234b70d]http://www.2carpros.com/forum/automotive_pictures/557674_Snapshot_20100318_2_1.jpg[/img:f5d234b70d]
Aug 3, 2010 at 6:14 AM
BLUELIGHTNIN6
  • 16,542 POSTS
it will only take approx. 3 labor hours to remove and replace the timing belt / water pump. that will be approx. $200 in labor fees. if you got a kit for 260 with all of that than the total charge shouldn't exceed $500 after taxes etc.. are added. that is, $200 labor + $260 parts + add. taxes/fees etc..= approx. $500. .
Aug 3, 2010 at 7:39 PM
