2003 Subaru Baja reset check engine light
BARTON
2003 Subaru Baja
How do I reset the check engine light on this car? It came on due to an O2 sensor (rear one 2nd in line) which a friend of mine just replace successfully last night. But how do we reset the light? Manual has no instructions.
For grins I tried disconnecting the battery but the light came back on at reconnection.
Sure appreciate any advice.
Aug 30, 2008 at 12:12 PM
2CARPRO JACK
  • 11,533 POSTS
Takes ascan tool to reset the light, sorry. You can probably buy an inexpensive one for about the same or less than a shop will charge you to clear it, then you will have it for later should you need it
try here
https://www.2carpros.com/store/index.php?main_page=index&cPath=1
Aug 31, 2008 at 1:40 AM
