Stuttering starting
30,000 MILES • 4 CYL • AUTOMATIC
JUEN
When starting car, starts to stutter when you turn the key. It does start. But yesterday, i turned the key and it stuttered then stopped and then i turned the key again and it started up.. And has started since, but i am worried it might be a starter or alternator.
Any advice would help, thank you..
Oct 16, 2019 at 2:16 PM
This sounds more like the fuel pump. The alternator has nothing to do with starting the vehicle. It only supplies needed voltage after the engine is started. The starter also would not make sense just because it actually starts. The starter just spins the engine and once it starts the starter is finished. So if the issue is sputter once the engine is started, then this points to an engine running issue. Sputtering is normally always a fuel issue so when you say it starts after you turned the key again, this is because when you first turn the key the fuel pump pressurizes the system. When the pump begins to fail it doesn't send enough fuel so turning the key off and back on causes it to do it again and this time it supplies enough pressure. I would replace the pump and go from there based on this info. However, here is a test on how to check the pump:
Oct 17, 2019 at 9:38 AM
JUEN
Well, i took it to the Honda dealership and they hooked it up to the diagnostic machine and it came back that nothing is wrong with my car. so my question to that is, on a diagnostic test would that show if it was a fuel pump? What does that test entitle. I am just so confused. they said my car was just cold because it was in the morning and i should of heated it up. but i drove it awhile before it did the sputtering at the red light. Grrr. Anyway thank you. Could you tell me what the diagnostic test covers? So i can easy my mind? Thank you.
Oct 17, 2019 at 10:06 AM
They are going to try and duplicate your concern and then check for codes. That machine does not test the fuel pump. You need to actually hook up the fuel pump. What I would do is drive the vehicle so that you know how to make it do it and then go take one of the dealership advisers or techs for a drive and you show them what it does. Unfortunately all to often they don't drive it enough or like you need to in order to get it to act up so they just tell you nothing is wrong.
Oct 17, 2019 at 10:57 AM
