Stuttering
2008 HONDA CIVIC
196,000 MILES • 1.8L • 4 CYL • FWD • MANUAL
MERCURYEVENTS
I just recently bought this car. When I got the car it was jerking while driving. Upon checking all the normal things it was found that the previous owner had put in the incorrect spark plugs, oil filter, oil and fuel.
I have subsequently changed the spark plugs, oil filter, oil and I am ensuring that the correct fuel is put into the vehicle. This seemed to have improved some of the performance.
I then subsequently took it into the workshop where they advised that the fuel pump needed to be replaced. The fuel pump was replaced and fuel tank removed and cleaned out.
I have taken the car back to the workshop and had them run a diagnostics check on the vehicle and no error codes were received.
The car is currently stuttering when pulling away. It has limited power, idling is a little erratic and sometimes it will not pass 4000 rpm's in first to third gear. It appears to drive well at freeway speeds, but when you drive between 60 and 80 in fifth gear it tends to jerk.
What could be causing this problem as the workshop cannot seem to find the problem?
Jun 10, 2016 at 12:41 AM
HMAC300
  • 48,601 POSTS
check fuel pressure it may still be off, or a bad fuel pressure regulator, and check for a vacuum leak as well as evaporator leak, smoke test both for that.also scan for codes and clean throttle plate an diac hole with choke cleaner it may be sticky.
Jun 10, 2016 at 5:05 AM
RENEE L
  • 1,260 POSTS
Hi Mercuryevents,
Here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning. Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com. Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
https://youtu.be/YV3TRZwer8k
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Jun 11, 2016 at 9:09 AM
