Stutter when accelerating when warm?
2014 FORD EXPLORER
176,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
HEATHER LIDER
  • 6 POSTS
I have the vehicle listed above Police Interceptor. A few weeks ago, I took it in for an oil change, it was driving perfectly fine prior. I left the shop and had to stop at a stop light immediately, when the light turned green my vehicle would not accelerate. Then at restart the engine stalled, a technician came out and was able to drive it back in. The check engine light came on, they fiddled with connectors etc., took it for a drive and noticed a stutter/driving hard. The next day an engine technician looked at it, there were no codes and no check engine light. The Mass Air Flow Sensor was not properly connected, they fixed that. Since leaving the shop I notice a lag/stutter when driving. It seems to drive fine when it is cold and before the engine warms up. Once the engine warms up, I can feel the stutter. It is noticeable when I am accelerating above 17MPH or 25MPH seems to vary. It is most noticeable when driving up a steep incline and creates a shuddering sensation. I do have codes for System Too Lean Bank 1 P0171 and Bank 2 P0174 and Catalyst System Efficiency Below Threshold Bank 2 code P0430. Prior to cleaning the MAF code P0420 Catalyst System Efficiency Below Threshold Bank 1. I replaced the MAF, that did not fix the issue. I am taking it to a different shop next week since the first said they couldn't find any problems however they cannot take a look at it until next week. I would appreciate any suggestions. Also, could I be causing more damage by driving to and from work each day?
Sep 29, 2022 at 4:37 AM
  • 110,244 POSTS
If this started after they worked on the vehicle and you have a lean fuel mixture on both banks, it sounds like they either left a vacuum hose off or the air box and inlet tube are not properly installed or tightened. Also, make sure they didn't bump any vacuum hoses or leave them disconnected.
Here is a link that explains how to check:
Let me know what you find.
Sep 29, 2022 at 12:05 PM
HEATHER LIDER
  • 6 POSTS
Replacements that have been made Purge Valve sensor, all spark plugs and boots. They said the sparkplugs and boots were completely shot and were hopeful that would fix the issue. Even after those replacements the issue is still happening, only between 25-40MPH, there are no issues above or below that. The shop that has it currently is completely lost as to the cause of continued issues. There are no longer any catalyst codes and fuel trims look good. They suggested I go to the dealership. At this point I am around $1,000.00 in with still no answer.
Oct 5, 2022 at 5:42 AM
  • 110,244 POSTS
Could the shutter be coming from the transmission? If you pay attention, is it happening in one gear and then going away once the transmission shifts?
Oct 5, 2022 at 10:20 AM
HEATHER LIDER
  • 6 POSTS
I just heard back from the third shop, which is our local Ford dealer, they are saying it is a bad torque converter. This is based off of a P0740 code. Their price to repair is $3,207.24 prior to any tax. I started calling around to get some other estimates which were way less than this one. The fourth shop I talked to, which is a transmission shop, said maybe it isn't the torque converter, maybe it is the clutch solenoid. I am going to take it to the transmission shop on Thursday so they can take it for a drive and hopefully they can narrow down the issue a little more.
Oct 11, 2022 at 6:37 AM
  • 110,244 POSTS
That is correct. This can happen as the result of a faulty torque converter, or the torque converter clutch solenoid (TCC).
I would have them check it for you. If it is the torque converter, I would be happy to provide the directions for you to replace it. The part should be under $200.00.
Oct 11, 2022 at 12:16 PM
HEATHER LIDER
  • 6 POSTS
Well, I went on a rather length drive with someone who specializes in transmissions and it has him a bit stumped as well. There were several times during our drive that he would have expected it to feel and see problems on his diagnostic tool. The issue does not happen consistently enough for him to feel confident the problem is related to the torque converter. He said it feels like there are 2 different things going on. There is a wobble that can be felt above 60, which to him feels like a tire issue. He recommended new tires, which I was aware I needed; however I do not want to spend $1000+ on new tires before identifying the cause of the lag/slip and the cost of those repairs. After our 40min drive and discussion he suggested starting with checking the fluid levels next week. There were no current codes. I will let you know what I hear next week.
Oct 14, 2022 at 4:26 AM
  • 110,244 POSTS
Thanks for the update, Heather. If you have a chance, let me know what you find. I'm interested in knowing.
Oct 14, 2022 at 2:55 PM
HEATHER LIDER
  • 6 POSTS
Update: Transmission fluid was around a quart and a half low. The shop put in an additive and topped up the fluid. They asked me to drive it around for a week or so and touch base with them again. I am still having some symptoms when the engine is warmed up and between the same speeds; it is worse after taking somewhat sharp left turns while accelerating (ex- our neighborhood has a tight roundabout). The sensation now feels more like a surge rather than a lag or drop out. It seems to have a consistent pattern when it does happen. I did leave a voicemail with the shop but haven't heard back yet.
Oct 28, 2022 at 6:16 AM
  • 110,244 POSTS
Hi Heather,
By chance, has the transmission ever been properly serviced with a new filter? Also, there could be a restriction in something like the cooler.
It's odd that it's worse when turning.
Oct 28, 2022 at 3:01 PM
HEATHER LIDER
  • 6 POSTS
New Odd development.
I had to take my vehicle out of state last week, so I had to replace my tires. I did not feel any of that surge sensation the whole time I was out of town. As odd as I thought it was, I thought maybe the tire change and balance had fixed the issue. However, now that I have done some driving back home the sensation is there again. I am wondering if it could be something that is impacted by elevation? At home the elevation is 1611ft, and where we were most of last week was right around 830ft.
Dec 19, 2022 at 3:58 AM
  • 110,244 POSTS
The higher the altitude, the more you will experience a loss in power. As a rule of thumb, you lose 3% of the power for every 1000' above sea level. That is simply the result of less oxygen.
So, to answer your question, yes, that is very possible. If you have a live data scan tool, you can check the short-term fuel trims to determine if the computer is out of specification as far as the air/fuel mixture is concerned.
Dec 19, 2022 at 8:20 AM
