Car will crank but not start
295,000 MILES • 2.4L • 5 CYL • 2WD • AUTOMATIC
ADAM CONNER
Will turn over but it won’t start, it’s a quick sounding when it turns over.
Feb 15, 2019 at 9:41 PM
  • 110,248 POSTS
Welcome to 2CarPros.
If the engine is turning over faster than normal, there is a chance the timing belt broke or has jumped time. That is a concern because this vehicle has what is known as an interference engine. Basically, there isn't enough room between the valves and pistons and they can hit and be damaged if timing jumps.
With that being said, I need you to perform a compression test. Here is a link that shows in general how one is done:
Start with that and let me know the results. If I misunderstood what you meant when you said it is cranking fast, let me know.
I will watch for your reply. Also, feel free to ask questions if you have any.
Feb 16, 2019 at 3:35 PM
