stumbling
88,000 MILES • 1.2L • 4 CYL • 2WD • AUTOMATIC
ORGASMICA
I have a pick up truck. it acts like it is gasping for air/gas when you are starting it or getting her moving. She chugs and pukes and sometimes backfires. I have replaced both O2 sensors and the catalytic converter is clear. I have used carburetor cleaner, and now I was recommended this product called "Sea Foam Spray" engine cleaner and lube. did not work. Help! Beth
Sep 6, 2017 at 2:46 AM
  • 55,732 POSTS
Hi Beth,
I know you might have done this already but I need to ask, have you replaced the spark plugs recently? If not I would start there and use AC Delco plugs.
Here is a guide that will give you an idea on how to do the job:
https://www.2carpros.com/articles/how-to-change-spark-plugs
This guide can help as well.
https://www.2carpros.com/articles/engine-hesitates
Please let us know what happens so it will help others.
Cheers, Ken
Sep 7, 2017 at 3:12 AM
