Stuttering
200,000 MILES
LAMAR WALKER
The van cranks but stutters then cuts right back off. Trying to resolve the issue but having no luck.
May 18, 2019 at 11:20 AM
  • 110,248 POSTS
Welcome to 2carPros.
If the check engine light was staying on when it runs, the first thing you need to do is check for diagnostic trouble codes. Here is a quick video showing how it's done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times a parts store will lend or rent one to you. If the light was on, you really need to check for codes.
Now, based on your description, it sounds like it could be a fuel related issue. If you are unable to rev the engine to keep it running, that is what I would suggest checking first.
Here is a link that shows in general how it is done:
Here are the manufacturer's specs for pressure.
Fuel Pressure (Key ON, Engine OFF) .................... 379-427 kPa (55-62 psi)
________________________________________
Start with that and let me know the results. Also, if you have questions or more information that may help, let me know.
May 18, 2019 at 3:26 PM
