Stud on from ball joint will not come out
170,000 MILES • V6 • 4WD • AUTOMATIC
BENSON
My ball joint snapped while driving and i can't get the stud out from where it broke off. I got the nut off below but the stud wont come out. What do i do?
May 11, 2020 at 4:57 AM
STEVE W.
  • 15,390 POSTS
They can bind in the taper really tight. Usually I'll get them free using 2 large hammers. You put one hammer on one side of the knuckle where the stud passes through. Then give the opposite side a good hard hit. The idea is that the impact squeezes the hole and deforms it for a moment and it comes loose. Another option would be to use a torch to heat it up, the MAPP gas torches you can get in hardware stores will work for that.
May 11, 2020 at 6:29 AM
