stuck woodruff key on crankshaft
170,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
RICK DAVIS
Could you give me some advice on what is the best way to remove a stuck Woodruff key on the crankshaft? My vice grips lock down tightly but eventually slip off every time.
Sep 24, 2016 at 9:53 PM
HMAC300
  • 48,601 POSTS
if there is no silicone holding it or some other sealer tap on one end and that should loosen it if it is a half round key, if square on bottom then take a small chisel and tap end so it should move out of hole.
Sep 25, 2016 at 1:23 AM
