I don't use 4WD often, because it always gives me an issue. Anyway, I shifted into 4HI to test it, I could not move at all. It was in 4HI, is it possible the lever is broken and it was actually in neutral? Anyway, I shifted into 2LO and couldn't drive. So I put it in park, turned off and started my ignition again, I could drive in 2Lo now. I drove home in 2Lo, then in my driveway tested 4HI again, it worked this time. Yes I am shifting only in neutral, I then tested 4lo and it worked. Shifted into 4Hi, and tried to get back into 2Lo. Now I am stuck in 4Hi, can't shift downward to 2Lo, what do I do? Please help, thanks in advance and hope you're having a great day.
Jul 10, 2019 at 5:44 AM
