Transmission does not shift out of park with foot on brake?
10,654 MILES • 4.3L • V6 • 4WD • AUTOMATIC
DAVE BOBO
doesn't come out of park with foot on brake and taillights work?
Aug 26, 2022 at 4:13 PM
  • 55,748 POSTS
The first thing we need to do is check the fuses under the hood, B/U LMP #25 and BTSI with the key on to see if they have power. here is a guide to help and the fuse location in the images below:
Aug 27, 2022 at 3:25 AM
DAVE BOBO
both fuses have power. my shifter is on the column.
Aug 29, 2022 at 9:51 AM
  • 55,748 POSTS
This leaves the shift lock solenoid being bad.
Here is the location so you can see if it is getting power and a guide to help you test it.
Aug 30, 2022 at 5:27 AM
