Stuck in low range
220,000 MILES • 3.0L • V6 • 4WD • MANUAL
TREVOR GOODWIN
As above, diesel.
4 low light flashing.
ABS light on.
Center differential lock light not showing.
Hi lo selector appears not working.
checked fuses could not find met.
followed recom. procedure to disengage.
Feb 22, 2021 at 9:28 AM
We need to start with checking for codes. I suspect that this is being disabled due to a larger issue which should have some codes to go along with it.
https://youtu.be/rTtAnsOlZU4
We don't have a manual on this vehicle but we should be able to figure out possible causes once we know what codes are there as they will point us to a specific system. Then based on your other symptoms we should be able to narrow it down.
Thanks
Feb 23, 2021 at 11:56 PM
