Stuck in first and shuts off at stop, please any advice?
60,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
96JEEP
I have the vehicle listed above a 4.0 i6 with a 42re transmission. I had a leak between the bellhousing and the block, so I replaced the seal between the transmission pump and the torque converter. Put it back together, still leaked. So, i dropped the transmission again this week and put a brand-new transmission pump and torque converter on. I got it done today, fire it up and the leaks gone! but now I have a new problem. The vehicle won't shift out of first no matter the RPMs, and it shuts off when you come to a complete stop. Any help is greatly appreciated.
Oct 31, 2022 at 3:26 PM
  • 55,649 POSTS
It sounds like the torque converter is defective, does it stall in reverse as well? Also, when you installed the torque converter did the installation go okay?
Here is a video of the correct way to install the converter:
https://youtu.be/ZC7xHVMKLRw
Can you please shoot a quick video with your phone so I can see the engine stall? That way I can tell for sure what's going on. You can upload it here with your response.
Nov 1, 2022 at 2:58 AM
