Stuck in 4 wheel drive low?
13,300 MILES • 6 CYL • 4WD • AUTOMATIC
NICK3611
Hey, my Trail Blazer is stuck in 4wd drive. how do i get it out?
May 12, 2017 at 3:43 PM
HMAC300
  • 48,601 POSTS
scan for codes first and check fuses either can cause it then check encoder motor to see if it is working and getting power. that is a high failure rate item. Here is how you can change it out in the diagrams below.
Apr 25, 2021 at 4:21 AM
