Stuck in 4 lo?
150,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
APRICOTV
My vehicle is stuck in 4 low, the indicator light stays solid on my 3-button dashboard switch. When I am in park I switch to neutral and push 2 hi the 4lo light stays solid and the 2hi light blinks for a couple seconds then shuts off. I hear the box clicking I've backed up went forward pulled the switch and had it checked out if back in disconnected vacuum hose lines jacked up right side to check it that way, I am losing hundreds of dollars because of this, help!
Dec 19, 2022 at 9:46 AM
  • 55,743 POSTS
The first thing we need to do is check the fuses.
here is a guide to help and the fuse locations as well:
Here are the fuses that run the 4wd system. Check out the images (below). Please let us know what happens.
Dec 20, 2022 at 2:28 AM
APRICOTV
I've tried everything to get my blazer out of four-wheel drive low it will not disengage I was curious if I disconnect the under battery tray actuator if it'll take me out of four-wheel drive low also I was hoping you could tell me exactly how I take off the encoder motor pull the spline and turn it counterclockwise back into two wheel drive it's been months my vehicle has been sitting in one spot I've been sleeping in it because of it please help me
Feb 15, 2023 at 8:54 AM (Merged)
