Stuck in "Limp Mode" (Second Gear)
1994 CHRYSLER NEW YORKER
180,000 MILES • 3.4L • V8 • AUTOMATIC
MAVBLOCK11
Hi.
I purchased this car a while back for a good deal and didn't notice a problem at first. Although I am sure the issue was there from the beginning. When I go into drive it is very slow at acclerating. Then there is a lurch or bump and the transmission is stuck in a gear I believe it is second.
I switched the transmission fluid today and it didn't seem to do anything. Are there any suggestions you can give me?
Apr 27, 2016 at 11:36 AM
CARADIODOC
  • 34,381 POSTS
Yup. Getting stuck in second gear is "limp mode" that allows you to drive slowly to a repair shop without needing a tow truck. There will be a diagnostic fault code stored in the Transmission Computer.
As a general rule, if it starts out in second gear as soon as you shift into "drive", it is likely to be sensor-related or will have something to do with the wiring. It goes into limp mode as soon as the problem is detected. If it starts out in first gear like normal, then bangs back to second gear during or right after an up-shift, it is more likely to be related to slippage in one of the clutch packs.
The same wear takes place that has always occurred since the beginning of automatic transmissions, but with older hydraulically-controlled transmissions the shifts became sloppy and sluggish, and you had a few years of warning that a rebuild would be needed pretty soon. With computer-controlled transmissions introduced by Chrysler in 1989, the computer knows how much wear has taken place and it adjusts the engage and release times of the clutch packs to overlap a little to maintain a solid, crisp shift quality. The advantage is that ability to learn the needs to maintain the desired shift characteristics and make those adjustments. The disadvantage is you don't get that year or two of warning that wear is taking place. It continues to shift like a brand new car.
It IS possible for an experienced transmission mechanic to get a good idea of the amount of wear by reading the "clutch volume index" (CVI), on a scanner. That is a set of four numbers corresponding to the volume of fluid it takes to fully apply each clutch pack. As the plates wear down, more fluid is needed to apply them. That is how the computer knows how to adjust the shift points, . . . until the day comes when it can't adjust enough to prevent slippage, then it goes to limp mode.
Apr 27, 2016 at 11:42 AM
MAVBLOCK11
So if I were to get the error codes from the computer could you diagnose those?
Apr 27, 2016 at 12:31 PM
CARADIODOC
  • 34,381 POSTS
You need a scanner to read the codes. Simple code readers only read codes in the Engine Computer. Your mechanic will tell you what they indicate, but get the exact code numbers from him too. I can look them up online if I have to but it takes me a while.
Apr 27, 2016 at 12:52 PM
