Replaced CV axle, tie rods, bushings, bearings,. Stub shaft keep popping out of transmission
Mar 27, 2018 at 12:17 PM
✓Experienced Mechanic
make sure that there is a "C" clip on the end of the spline, this is what holds the shaft into the housing, it may be deformed or missing.
Mar 27, 2018 at 8:44 PM
Good morning.
When you replaced the axle, was there a snap ring on the end of the shaft that went into the trans-axle? if that is missing or damaged, it will come out.
