Creaking noise still there after replacing the struts front and back, do they need to wear in?
90,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
MEOW2K47
  • 10 POSTS
had struts replaced front and back. Do they need to wear in?
I still have that creaking noise.
Mar 26, 2025 at 8:53 AM
STEVE W.
  • 15,385 POSTS
Shouldn't need to wear in. Creaking can be multiple things. Control arm bushings, sway bar links, even the subframe itself can creak if the mounts are failing. When do you normally hear it, and can you duplicate it by pushing down on the vehicle's fenders or bumpers?
Mar 26, 2025 at 9:55 PM
MEOW2K47
  • 10 POSTS
when you back up and going forward it makes the creaking sound and just driving also. doesn't make any sound when pushing down fender or bumper. had control arms and ball joint assembly replaced a year ago.
also sway bar links were done also.
Apr 2, 2025 at 9:55 AM
STEVE W.
  • 15,385 POSTS
Chassis noises can be hard to track down. What most shops use is a tool called a chassis ear. Basically a few microphones that you attach around the suspected areas, then you switch each mic on and off while listening to where the sound gets louder. Then you move them to that spot and repeat until you find where the sound is loudest. With a creaking like you have where it is only while driving and not there when you bounce it suggests it isn't the suspension bushings but something that rotates, like a bad CV joint or a failing bearing, especially if it's a rhythmic sounds. Using a tool to track it down would make it much faster, but I know of folks you buy a couple cheap wireless mics and use them in a similar fashion.
Apr 2, 2025 at 12:58 PM
MEOW2K47
  • 10 POSTS
does the strut assembly come with everything you need to replace struts, or could there be other parts that should have been replaced at same time?
Apr 3, 2025 at 1:07 AM
STEVE W.
  • 15,385 POSTS
The struts won't creak just from driving. They creak when turning or hitting rough roads. It depends on the strut. If they used a loaded strut, those come with all the pieces attached.
Apr 3, 2025 at 5:50 AM
MEOW2K47
  • 10 POSTS
thank you for the knowledge.
Apr 3, 2025 at 1:02 PM
STEVE W.
  • 15,385 POSTS
You're welcome.
Apr 4, 2025 at 8:56 AM
MEOW2K47
  • 10 POSTS
when I brake, it makes the creaking sound. When I back up and then go forward is when I hear it the most. I hear it in the front and back. don't really hear it when going at high speed. When driving at slow speed I can hear it more predominate. it was creaking before I put new struts in. also rack and piñon and sleeve for harmonic balancer.
Apr 7, 2025 at 9:55 AM
STEVE W.
  • 15,385 POSTS
Being a 2009 it could be subframe bushings. What you hear might be them shifting under the different forces. When you are going faster they wouldn't move as much. That is where the Chassis Ear would help as you could listen to the parts as they make noise and easily track it down. Then you can make an informed decision on the repair.
Apr 8, 2025 at 3:26 AM
