Strong rubbing when clutch pressed
132,000 MILES • 2.0L • 6 CYL • 4WD • MANUAL
SILORS66
Hi, I'm hoping someone can help me as I'm lost. I parked my vehicle up, no issues when I left and returned to it two weeks later; to find it starts fine and still selects gears, but when clutch is pressed all the way in it's almost as if something is spinning behind it knock Ng the pedal up and down. Any ideas as to what it could be? I would be grateful. many thanks in advance.
Apr 13, 2022 at 2:45 PM
  • 110,251 POSTS
Is there any change when you release and press the clutch pedal? Does the clutch seem to be working properly?
There is a release bearing which is part of the clutch system that can make noise when they start to fail.
Is it loud enough for you to record and upload for me to hear?
Let me know. Also, please confirm the model and engine size.
Apr 14, 2022 at 12:34 PM
