Strong engine noise through the speakers
2000 MAZDA PROTEGE
90,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
CARPS
Hi, with no changes made, suddenly, a very strong engine noise sounds through the speakers. No have any amplifier nothing. Cannot hear the radio anymore, all you can hear is the engine noise. Could it be a bad alternator ? Thank you.
Jan 10, 2017 at 1:34 PM
JOHNNY G.JR
  • 320 POSTS
Grab a DVM, select A/C volts,check alternator for a floating A/C voltage,positive lead on post, negative lead on battery.
Jan 10, 2017 at 3:23 PM
  • 31,937 POSTS
Very probably an alternator issue, best to get it tested. also, make sure no earth straps have come loose or broken.
Jan 10, 2017 at 3:38 PM
