strong car vibration and rpm down while using the aircon
15,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
CHAI30
My car has a very strong vibration and the rpm goes down everytime i turn on the air con.
The vibration is not normal.
The throttle body already clean .
But still the same problem occur.
Oct 18, 2015 at 5:54 PM
HMAC300
  • 48,601 POSTS
chek belt and tensioner, it's kind of normal for rpm to drop when a/c goes on. you can also disconnect belt and start engine see if vibration goes away that will tell you its in accersorie drive
Oct 18, 2015 at 11:50 PM
