Front end noise
166,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
NATHAN6219
I was told my car had a loose wheel bearing due to the noise in the cabin coming from the rear passenger side.
I have replaced the bearing and the hub. I have also put on a new caliper, new brake pads, new sway bar new links, new bushes, but the noise is still there.
When I am out side the car I grab the wheel and move it forwards and backwards and I can hear a loud noise but am totally unsure where it's coming from.
Oct 19, 2020 at 9:09 PM
We may have tie rod issues or some other suspension component but let's start with a video of this noise so that we can hear it. If we hear it we will either know what it is or at least better understand the things that it could be.
Here is a guide that will help in general. Even if it doesn't help with this issue it could help others that visit this post with suspension noises.
https://www.2carpros.com/articles/popping-noise
Let us know if you can get a video and we can go from there. Thanks
Dec 11, 2020 at 4:48 AM
