Strange noises, then no reverse
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
AUDREY B PETERS
Van started making grinding noise, I thought was the brakes. Backed out of driveway, heard a clunking sound. A little way down the road, heard rattling sound, so I turned around and drove back home. Pulled too close to the house, so I tried to back up- no reverse! I do not see any leaking fluids. What could it be?
Dec 16, 2017 at 12:34 PM
CARADIODOC
  • 34,415 POSTS
Now do you have only no reverse or are all forward gears gone too? If you cannot move either way, a good suspect is a broken outer CV joint on one of the half shafts. You are going to need a live person to peek underneath, just inside the two front wheels. A clue is you should hear a rotational rumbling and thumping noise when you shift to any gear with the engine running. Another potential clue is you can push the van when it is in "park".
It is not practical to replace the CV joint. It is less work and less expensive to just install a rebuilt half shaft. These used to cost as much as $150.00, but I bought a brand new one for my 1988 Grand Caravan a couple of years ago for just $65.00. The outer joints make noise long before they break. Mine made a clicking noise when turning and backing up for about three years that I ignored.
If the van will still move forward under power, the half shafts/CV joints are okay. Losing only reverse is not real common, but is due to a broken part inside the transmission. Specifically it is a "band" that breaks, but that does not cause a noise. Your description of a noise is what pointed me to a CV joint.
Dec 16, 2017 at 1:14 PM
AUDREY B PETERS
I appreciate your diagnosis. Turns out, brake pad broke off & got wedged. That's why it wouldn't back up!
Dec 23, 2017 at 10:02 AM
CARADIODOC
  • 34,415 POSTS
Dandy. Very unusual cause, but happy to hear you solved it.
Dec 23, 2017 at 11:47 AM
