Phone not working
30,000 MILES • TURBO • AUTOMATIC
GANLET
The head unit in my Jetta has suddenly stopped connecting to my iPhone, it just gives a constant connection fails error. In addition whenever I start my car the radio is basically reset, it doesn't remember any saved stations and it starts at the car play screen regardless of where it was when I turned the car off. I have to assume the two issues are related and my theory is that it is probably a fuse, but i'm not sure which fuse it might be. the manual doesn't have a fuse guide. I'm hoping someone can point me in the right direction.
Thanks
May 20, 2019 at 5:37 AM
  • 55,721 POSTS
It sounds like one of the fuses blew (13, 31 or 51). However, to be sure here is a guide to help us test the fuses and the fuse location with the radio wiring diagrams so you can see how the system works:
May 21, 2019 at 8:16 AM
GANLET
Thank you for the response, I will try out your suggestion and let you know.
May 22, 2019 at 2:01 AM
  • 55,721 POSTS
Please do.
May 23, 2019 at 4:20 AM
GANLET
the guide you provided didn’t match my car exactly. the layout is the same but my car doesn’t have all the fuses listed. I’m not sure if it matters but I have a Jetta SE. In the engine box 13,31, were missing. In the cabin 13 was missing but 31 and 51 was present and unblown.
May 23, 2019 at 5:02 AM
  • 55,721 POSTS
It sounds like the head unit is going out or needs an update. We can find out for sure if we do a CAN system scan. here is a video to help see what needs to be done:
https://youtu.be/InIlnsjOVFA
May 26, 2019 at 4:21 AM
GANLET
It ended up being the head unit, had to replace it. Thanks for your assistance.
Jun 28, 2019 at 12:25 AM
  • 55,721 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Jun 29, 2019 at 9:36 AM
