Hi!
Man this truck is killing me. Bought as a project and im sorting thru a lot of hairy wiring to get the fuel pump to spit ultimately. However, please take a look at this pic and let me know if the gray 2 wire connector should be there. The image is the backside of the fuse/relay panel under the hood and the bottom is at the top so the fuses in question are initially on the top right, battery 50A and Lighting 50A and they are jumped to the EcmB and RR defog buses with the 10g 2-wire connector via main bus. Is that supposed to be there or is it retarded? I have so many electrical issues it seems like this is the root because it would give full time power things that shoukd only have key on run or accy position. Any help would greatly be appreciated. Steve
Nov 29, 2016 at 8:02 AM
