Strange chirping sound
60,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • MANUAL
JTOP
Hey guys! Thanks in advance for the help. I've got a strange sound. I'll be as specific as possible.
The sound is a rhythmic chirping that varies in speed based on engine speed. It sounds similar to a warped rotor.
It generally only happens after the car is warmed up, and resolves completely when the clutch pedal is pressed, starting again immediately when the clutch is reengaged.
The sound continues while the car idles. Sound seems to be coming from just behind the engine somewhere under the inter-cooler. As far as I can tell it isn't related to any other systems.
There are no warning lights, other sounds, or performance issues. Nothing is visibly wrong.
Thanks again for the help!
Dec 21, 2019 at 11:17 PM
JIS001
  • 3,412 POSTS
There was bulleting to replace the drive belt with an updated version if you had a chirping sound coming from that area.
The bulletin number was 02-168-17
I do not know if they would replace it for you under warranty or not but if you provide the bulletin number and your VIN they will tell you for sure or at the very least sell you the upgraded belt if your VIN falls within there range for the bulletin.
Dec 22, 2019 at 9:51 AM
JTOP
Would a squeaky serpentine belt stop making noise when the clutch is pressed? I did a little more checking and the AC compressor clicking on or off doesn't make a difference either (except for making it harder to hear). It seems like suddenly increasing the load would effect the sound.
In any case I'll head over to the local dealership and see if this service was ever taken care of. It's a good thing to look into.
Thanks for the tip!
Dec 22, 2019 at 8:35 PM
JTOP
Checked the VIN listed. Not a match anyway. :/
Dec 22, 2019 at 8:47 PM
JIS001
  • 3,412 POSTS
No it would not. Sounds more like the throw out bearing in the clutch. There is also an updated bearing.
Dec 23, 2019 at 4:33 AM
JTOP
Fixed the problem today. It was indeed the throw out bearing, but fortunately it didn't have to be replaced.
It's apparently an issue with later WRX's. There is way too much play in the clutch and that causes various problems. A quick adjustment of the clutch pedal serves a dual purpose of fixing the chirping issue and making the clutch feel tighter and more responsive. 20 minutes and no new parts.
Thanks again for your help!
Dec 25, 2019 at 12:38 PM
